sayow
So I just installed a brand new and complete AC system on a 2000 LS. Unfortunately when it is running I get a strong mix of heat and ice cold air coming out of vents.
I just had a new DCCV installed a few months ago, so this is likely NOT the issue. So far in my research I have found the following possible causes:
1. Aux Cooling Pump below the DCCV
2. Climate control Module
3. Evap sensor
4. AC control module (no idea where this even is)
Where to start? My exact symptoms are:
* Cold and Hot air mixed in each vent (not specific to any vent)
* The issue gets worse at speed, better at idle but heat always present
* Turning recirculate on or off does not change anything
* If I turn the AC to defrost and/or floor, its much colder
Thoughts or Feedback is appreciated.
3. Evap sensor
