shiryu0
WITH CAR OFF:
turn parking lights ON, neon turns ON, then it turns OFF, a flash kind of thing, really fast.
with parking lights ON, press brake, it either works once or twice, then it flickers by itself, then turns OFF
turn everything off, press brake, it does the flashing thing; press brake, neon turns on, then off.
turn everything off, lock the car, hit the panic button on the remote, does the flashing thing, making it look out of sequence with the rest of the tailights, which are working correctly.........
WITH CAR ON:
perfectly normal
checked the ground and wiring to the ballast, looks good, with the car on i moved the trunk up and down to check see if it was a wire cut or something, nothing, worked fine..........
neon ballast? headlight switch? brake switch?
WITH CAR ON:
perfectly normal
