need to know
slickemhoundd
Sewell
Im replacing my fuel pump with a 255 lph, now im doing it now cause it will come in handy later on but as of right now would the stock regulator be okay? What i do know is that the fuel pressure will go up a tad, and it will cycle th fuel almost twice as much. Is it safe or do you think i should get the adjustable fuel pressure regulator off the bat? Anything is appriciated
As far as I have seen stock regulator is fine. Its not the pressure that will go up, its the volume of fuel flow, the rate.
The regulator will not go bad right away, but from what I've heard it stresses it and may cause an earlier failure.
