need to emty gas tank how?
There seems to be some kind of restrictor that prevents pushing a hose through to siphon it. i guess i will need to use my right foot :)
Go thru the front wheel well and disconnect the fuel filter and place a rubber hose on and put other end in an empty 5 gallon gas can and use the key to pump the tank out
1. Make sure your fuel tank is FULL
2. Place roughly 1.5Grams of RDX on the bottom of the tank. Shape it in a ball.
3. Insert a blasting cap. (alternately, you can use a hammer to strike the RDX with, but I REALLY DO NOT RECOMMEND THAT)
4. Set off Blasting Cap. Instant hole in the tank that your fuel will drain through.
Alternately, use RoadBoss' idea.
OMG i just tryed this and not the fire deparment is on there way!
Well, you see, someone picked up the sandbox. Then they shook it all around. Lo and behold a frog.....or rather a frogman fell out. Welcome home.
I never got past the word RDX before I ran outside.
