need some info
wfcrawford
crawfordsville
i put a 96 mark motor and trans in a ffr coupe and i can not get it to shift in to 4th. ??? i have not calbrated the speedo yet. will that have an affect on the shift points. all new mercon v and filter
thanks
wilburhttp://s175.photobucket.com/albums/w123/1wfcrawford/?action=view&current=complet001.jpg
thanks
do you have a switch on the shifter for turning 4th (od0 on and off like it would be in a mark,and do you have o/d light to confirm the switch action?
maybe someone else can with more knowledge on this can chime in here,but do you have it running off a 96 computer or what is controlling it electronically?(the engine and the trans i mean)
my thought would be if you have the proper electronics controlling it you would not need a switch to turn "on" 4th gear only to turn it off.but i dont know for sure.
anyone?
