need pics of LS's on 18x7 wheels.
DarkMansLSEV8
Miami
Guys I need pics of LS's running 18x7 wheels. I have a set of 18x7 wheels that I took off my MarkVIII and I would more or less like to get a picture of how they would look on the LS. Thanks!!
I could be wrong but I think that's a different bolt pattern
its the same bolt pattern, b/c Ive seen MarkVIII's with LS wheels. Plus I know that we share bolt pattern with birds/cougars/MarkVIII's, dont we?
I just spoke to my seller and he said that the wheels will fit, the ls, just like marks,birds,cougars,volvos, and jags. pics please?
If you go to tirerack.com you can see what an 18 ' wheel with the size tire you plan on getting will look like. You can even select your car color to give you a better picture.
Just go to wheels and put in your vehicle make and model.
still on the hunt of them picutes. Tirerack has no 7inch wheels, they are all 7.5's. Thanks.
Sorry I have 20s. But FYI the Marks bolt pattern is the same the offset is different and can cause fitting issues.
Your wheels will likely fit as even with a smaller offset, the 7" wide wheel will still likely clear.
Just pick an 18" wheel, the view is from the side and the width of the rim is irrelevent. For tire size just substitute something with the same sidewall height. You can calculate the sidewall height from the tire size.
