Need Parts? Check this out!
  • Thread starter Thread starter GrayGhost1
  • Start date Start date
ken, lse tips. will those fit 03+? Also are they weld on? thanks!
If I'm not mistaken the 03 and up systems have a straight tip through the rear valance. I don't think these will fit since the opening isn't very big. However, these are bolt on.
yes straight through. I could widen the hole. do these drop down to go under the valence?
LOL, go ahead and grab them, I already have dual tips on the rear... I'd just like the real thing though. That's some sweet action there.
they probably won't work w/my 03 properly. I want duals bad, any advice?
I don't think these will work with the 03 and up LS's. The opening isn't big enough.
got the Tips :) :) :) :) took me all of 30seconds to decide after I saw them.
I know someone has duals on an '03. IIRC they had to cut the lower bumper valance with a dremel or other cutoff tool. Or was that to fit the larger tips on a Gen I LS? Yes, I am confused.
Either way, you should be able to do it. I bought mine from Hedman Hedders for cheap money. I'd bet dual exhaust tips would look pretty sweet and it shouldn't be that difficult to do.
The original LSE tips are not going to line up with the 03up cut-out, just look at them. To put them on a non LSE 00-02 would probably work fine as it has no cut-out to begin with so you can do it as needed.
