swdobbs
My 2002 LS 3.9 w/ 95k miles developed a very noticeable miss at idle all the sudden one day after work on start up. It surges at stop lights, running ugly but No code.... yet! It still runs decent, just shakes bad at idle and has a miss at 46-50 mph under light load. Downshifts and pulls hard up past 100mph.
After reading this forum the 18 months I've owned the car, I expected coils, called max ordered motorcraft coils and VCG kit.
Replaced all the coils, no oil on any of them DRY spark plug wells (that must be like winning the lottery to an LS owner), replaced the spark plugs with NGK iridium. Old plugs uniform light tan discolored, none visually fouled, looked like oem equipment autolites platinum.
Still a miss at idle after replacing coils and plugs. I believed I have narrowed the miss down to cylinder #6 (drivers side 2nd from front). Runs just as bad with that coil unplugged, whereas the other coils when unplugged all make the idle and the miss far worse. I checked the spark from the #6 coil blue, pretty good consistent snap on the grounded screw driver compared to the other cylinders. I replaced the new coil with one of the other new coils, no change. I listened to each cyl with the socket extensions pressed to the ear, has a light tap coming from #6, doesn't sound like an injector tick, but I haven't heard one an LS injector go bad only chev LT1's.
So now what.... injector? (old spark plug looked same as the rest)
If it was a burnt valve, wouldn't it run bad all throught the rpm range?
Carbon on the cyl?
What would the veteran LS owners check next or do now?
Dealer is about the only option for a scan, no checker/autozone/auto parts stores that have code readers.
I really appreciate any opinions, I like the car but it sounds like its coming apart at idle.
Thank you.
Carbon on the cyl?
Thank you.
