zmt325
first off the car is a 93 with 120k on it and it runs horribly.
symptoms are in order of when i started noticing them
#1@ 3500 rpm car stumbles and misses bad! if you stay in it for a min it clears up a little, but is down on power and misses pops and cracks through the rest of the rpm range. symptom is much worse when the car is cold.
could this be an imrc problem? couls this be bad a coil ?
#2 takes for ever to drop rpm
vacuum leak is the only thing that crosses my mind on this one
#3 stumbles when coming off the line from a dead stop.
I have no idea on this one
#4 throttle response is terrible
tps?
did a koeo diagnostics test a while back. received a code that it was running rich ( amongst many others). i am about to pull it into the shop and do a koeo and koer diagnostic check for codes and will get back to you guys afterwards
things i have done to the car. spring conversion, jmod, ford racing wires, walbro 255, 2.5 inch exhaust with 3rd cat,muffler and resonator delete with 1 xpipe. replaced the plugs last week thinking maybe that was it.
i am heading to orileys to get some map sensor cleaner and a vacuum gauge and going to look and see how much a fuel pressure tester is.
should be on here in an hour or 2 with the codes that pop up
one more thing this car was chewed to pieces by a mouse and i am thinking that it may be a chewed wire or vacuum line. i have visually inspected everything i can think of (or see) and have found no chewed lines
Please Any suggestions would be awesome. you will not be put down for suggesting stupid things. I just need to know where to start looking. I do not want to just start guessing and replacing parts.
THANKS FOR TAKING YOUR TIME TO READ THIS !!!!
zmt325
tps?
zmt325
