Need Help with rims for my 2002 LS V6 Base
loomis22
Colchester
I found these rims I really like: http://www.streetdreams.org/wheels/rims/Verde/Regency/Chrome/20/7.5 and I was wondering if they will fit my car with NEXEN N3000 tires found here: http://www.streetdreams.org/tire-selection.php?diameter=20.0&width=245.00&ratio=35.00
20" rims, bolt pattern is 5x108, offset is 38mm, center bore is 78.10.
They have a "choose rims by what will fit your car" and these rims and tires came up in the selection but I'm not sure if I want to trust it lol, so I figured I would come ask the professionals ;).
My car has stock suspension and everything so I'm not sure if that needs to be taken into consideration.
Thanks for the help.
They should.. They aren't a very wide wheel though.. And the cheapest tires.. Just sayin..
Here's a good calc..
http://www.rimsntires.com/rt_specs.jsp
I'm not made of money lol, hence owning a V6 lol, and I just had to replace the serpentine belt and the water pump (oh joy). I will shop around more for sure, I'm in VT so summer is a ways away so I got time to find whats right. Thank you for your input and the link, I appreciate your help.
I'm familiar with both of those sites. Found some wheels on streetdreams that I like also. The Verdes will fit with that offset. If you don't plan on lowering your car than you should be ok. Most peple who lower their LS try to run between 42-45mm offset so that rim is under the fender all the way and won't rub. I have 20"x 8.5 35mm wheels on my LS and they are evenly flush with the fenders. Hopes this helps you out.
you wont like the tires they are super hard they of course don't wear as fast but they make for a ruff ride.
Right on, thanks for the tip. I just don't want all seasons cause I will have separate rims and tires for winter so I rather just have strictly high performance summers that aren't gonna break the bank, any brand/model that would be a good ride but not break the bank at the same time? I still want 20's...
Oh cool. Thank you. I don't plan on lowering it but plans do change lol. I will keep this in mind.
