So, are you saying that air does not come out anywhere inside?
Did you check the defrost and the floor vents?
Have you tried it in both the recirculate and the fresh air settings?
Do you hear the blower running?
If you only get air on the recirculate position, when's the last time you changed the cabin air filter?
It's behaving odd. These are the steps I went through tonight...
• Tonight after work I started the car and the AC was on - left on from when I parked the car this morning.
• I could hear the compressor click on under the hood - the blower did not come on.
• The display said it was set to Auto at 60˚.
• Nothing was blowing anywhere.
• I turned off the AC.
• I heard the compressor shut off and the engine changed idle.
• I then pressed the "Auto" button with the setting set to 60˚ - same result - NOTHING.
• I shut everything off again - then turned the car off.
• Waited the few seconds and restarted the car.
• Pressed the "Vent" button selecting the "Dash Vent" setting.
• Nothing happened for a few seconds then the blower started blowing at it's highest setting (I had it set to this).
• Hot air was blowing out the vests (the outside temp read 113˚ - this is Texas).
• I then pressed the "AC" button.
• The compressor clicked on and it seemed to be working.
• I pressed the "Circulate" button and it seemed to be working.
• Drove home (45 minute drive).
• Shut everything off - then tuned it back on and it's working.
• I have not pressed the "Auto" button out of fear it will stop working all together.
Has anyone had this weirdness happen to them? It's freaking HOT in Texas right now and I need my AC to be as cold as possible.
Any ideas?
