66coupe
I'm hoping someone can help me out here. Today I had to change out my power steering pump on my 02 LS with the 3.9L. Since I ha dto drop the ac compressor I went ahead and replace that since the clutch was alittle loose on it. Well I get everything back together, recharged the ac and went to turn it on to check it and guess what! The ac clutch would not engage!!
I went through and checked everything. Fuses and relays are fine, system is full of r134. So i thought maybe a bad compressor? I took a power probe the the compressor and the clutch engaged perfect! So for some reason the compressor is not getting power?
I know the ac pressor switch controls it but I'm not sure how the 3 wire switch works? Anyone know how to jump it to check and see if thats my problem? Please help since I have no defrost now either! Thanks, Jason
