bitetto603
Hello this is my first post. I own a 2003 Lincoln LS 3.9 V8. There are a couple of things going on that have me stumped and I haven't had good luck with dealers. First thing that has been going on is when I start my car a loud rattle happens around 1500 rpms and occasionally when I accerlate too, but mostly when I start it from a cold start. I have had the coil packs replaced twice. First time for free under the recall but the Irwin mechanics forgot or didn't care to change the plugs along with it. This caused a snowball effect and my catalytic converter went bad. After getting no where with Irwin, I changed the coil packs a second time and plugs and bought a magnaflow cat system for my car. Things were great until I started hearing the "rattle" noise. I've heard over and over its just the heat shield but I'm not to certain.
Now onto the major problem. 2 days ago I was driving to work and my dashboard needles on the speedometer and rpm gauge went to zero while driving. The radio turned off, power steering went out, the message icon said check traction control, check engine light, red oil symbol, the chime noise, and a couple others. It only does it for 2 seconds at a time but it happens maybe 4 times on my 15 minute drive. Previously I had an issue with it saying E instead of D5 and that was corrected. Turns out it was the abs box contraption. A new one was put in. A new starter has been installed. New battery, new cat and coil packs. So I was hoping someone might know a cause of the electrical problems I'm having.
