A good performance tune will give you a little bit better mileage also if you don't have a lead foot due to the new performance. Some see between 1-3 mpg depending on the condition of the car, driving habits and driving conditions.
The claims of a custom tune making your car a gas mileage monster are plain BS. AFR's are AFR's are AFR's. There is only so much you can do with AFR's on a N/A high compression vehicle like the LS before you cross over into the area where you encounter a much higher chance of pre-ignition without any better results.
Performance tunes strive to make the car a more efficient system. Through doing this most performance tunes will basically offer more or less a similar amount of mileage increase than a "gas mileage" tune will do.
If you want more MPG out of your car the best way to do it is change driving habits. I can drive my wife's 01 JGC with the 4.7 V8 to 23-25 mpg on average if I change my driving habits just a bit while still driving somewhat normal.
you can also unplug two coils.... :shifty:
