Motor hesitates at full throtal/ wont shift.
boundry123
Sask.
I'm thinking of buying a 96 LSC with 146K, the motor hesitates and tranny wont shift at full throtal but if you let off the RPMs rise and it shifts.What could be the problem? Also what kind of fuel millage can I expect?
could be low on transmission fluid. What is the asking price on it?
You could get as good as 28mpg, but dont be disappointed if you get 24.
How doe sit idle? Hesitation could be IAC (Idle Control Valve), Throttle Position Sensor (TPS) or any other items, but generally nothing major.
A bad TPS could also explain the shift problem and the trans is VERY dependent on info from it.
