moonroof question...
wristel
sweden
I've got a 2001 Navigator with moonroof...
I got one question:
when i close the moonroof (holding the button down) till it stops.. there is a "extra lift" if i press the button onece more.. is tis a tilt function that is broken in my moon roof or is that the closed position?.. cant find ANYTHING in the users manual!
Moonroof Question
I don't quite understand what you mean by an extra lift. If it is anything like my Towncar; there are 3 main positions: 1: Fully up "Vent Position", 2: Flat or "Sealed Position", 3: Open or Retracted Position. When the panel seals properly; the moonroof should be quite flush with the roof line of vehicle.
If it helps you at all; please see my Moonroof Jammed Post. There are some ideas there and I can email you the pdf files for repair if you really need them.
happy Holidays!:D
sorry for my bad english...
the question was if there is a "vent pos.".. my moonroof just lifts 0.5cm in the back if you try to open it in the back(vent pos.)
if u like u can mail me at S_T_C_S@yahoo.se
