Moon roof wont open
foolzgold
col
I searched the "search" no luck, my moon roof stopped working today with no fore warning, I checked all the fuses inside and under the hood, My radio also quit working could the two be related ? What is the troubleshooting procedure? Thanks in advance.
Gen IIs have issues with the screws backing out on the motor and if you are lucky it just hangs loose the whole timing circuit gets messed up easy fix. Worst cse is it still enguages adn you can break the track when it get out of time (sequence).
On a Gen I Look at a fuse, kinda strange to have the radio and roof go out at the same time. Take the back access cover off and see if you get any volatage to the motor when depressing the switch (I used a stick to press the button from the back seat).
I do not have an access panel on my headliner, is there another place I can do a voltage check? Thanks Frat-
the moon roof started working today on its own, and I opened the radio and found a plug to the face plate loose from where I had trouble removing the radio. that was the radio on my 94 but the radio in my 95 is still inop, it has power, the cassette runs but all I get is static. . 'double din". so slowly I raise the dead. Thanks again
