Misfires/ Ignition Coil Codes-P0306,P2196,P0354,P0355
jtammerine
North Carolina
P0306- Misfire #6
P2196- o2 Sensor bank 1 sensor 1
P0354- Ignition Coil D
P0355- Ignition Coil E
Went to autozone and got an reading ok my car because the CEL came on last night. It flashed for about 10-15 sec. And stayed on I had my cats replaced about a month ago and it just happened. Anyone had any problems with these similar problems or have any ideas with the pricing? thanks
P0306- Misfire #6
Be cautions before you start throwing money at it...
I had a coil #7 code and the left fron O2 sensor codes when my secondary timing chain was on the fritz.
Save the trouble of replacing coils and o2's by doing the tensioner. Car now is timed correctly and runs great... That doesn't mean your is the same or that the codes are wrong, just Autozone scans are not the same as the dealer digonostic tool that can look deeper into the issue live.
My $.02
I Don't know what to do with my02 lincoln ls v8! code p0352 won't disappear!!!!
I already did this:
CHANGE VALVE COVER GASKET
CHANGE SPARK PLUG
CHANGE IGNITION COIL B (#2)
CHANGE FUEL INJECTOR
But still I have the code!!!!
PLEASE ANYONE HELP!!!!
THANKS IN ADVANCE
