Mass Air problems
Ricks90billblass
Sacramento
I've noticed that quite a few members, my self included have mentioned that their cars that were converted to mass air have a problem with running to lean and or failing emissions testing. Mine does both. I installed the MAF kit on the stock engine and had a lean condition right away and had problems overheating. Same problems existed on the 342 but magnified.
So here is a survey to see if we have something in common that might cause the lean condition. And together, maybe we can figure it out.
If your car was running correctly after the conversion please take the survey too, and state that your car ran fine.
Thank You in advance, Rick
What engine size?: 342
What is you ECM code: C3WT Ford part# F3ZF-12A650-FB
Mass air meter brand and size: C&L 73mm
Fuel injector size: 30lbs/hr
Cold air kit, Stock, : C&L elbow from MAF to TB
Intake: Pro Products Typhoon (GT40 in the garage)
Throttle body/EGR spacer size: Pro Products 70mm
Full exhaust: Yes 2 1/4 50 series flowbastards
Cats: yes,2 highflow Catco's
Auto or stick: auto
Did you piggy-back the old ECM to retain the factory cruise control: Yes
What EEC are you using? A9L, X3Z?
You didn't mention whether you had a custom chip burned for your EEC.
This is a must for your type of mods. If not, then you will surely have problems! :eek:
