Mass Air Filter Adaptor Size
JOHN1242
michigan
I want to use an adaptor that mates my mass air to a conical element. I have seen several of these some plastic ,some billet(accufab). what have you guys been using? what size do I buy?,any jegs or summit part number?
help!
thanx,
JOHN
You can use your stock one, just take it out of the box. Thats what I did. I ended up going back to stock thought because of the CEL i kept getting.
if you want to add a cone to the stock maf sensor you have to get an adapter made as the one in the box is squared at the filter end i had one made for $20 just took a 4" pipe cut a 2 in section out and welded it to a plate sanded painted and mated the holes to fit ,used the gasket from the air box, and also sealed it with rv silicone and it works great .just did this wed , then hooked up tuner i got from kk and i love it!
They sell them on line for about $30 you just need to search to find one.
Just do a MAF adapter search and I'm sure you'll find one. They are a 4" diameter.
