Mark VII parts that I need gone...
NYC LS8
Carpentersville, IL
Gates 6 rib serpentine belt (#K060806 21mmx2060mm O.C.). Brand new, never used, no cracks - $10
Gates 6 rib serpentine belt (#K060810 21mmx2075mm O.C.). Brand new, never used, no cracks - $10
Carter/Federal-Mogul stock replacement in-tank fuel pump. Brand new, never used. Comes with what's pictured (no sock). Sells for $110. Take it for $50.
KEM stock-type ignition coil. Worked fine when removed - $5
KEM KVR202B Heavy Duty Capacity stock-type voltage regulator.Worked fine when removed for 3G alternator set-up - $5
Center arm rest cupholders. Missing pieces that hang underneath - $15
LSC trunk lock cover. Some pitting around the edges. Couple of scuffs on the badge itself. This is the entire piece that mounts over the trunk lock - $15
Stock stereo amplifier. Was working when stereo was upgraded. Not sure if it's the JBL amp or not. Mounting tabs are broken - $15
Stock crank pulley (5"). Removed when underdrives were installed. (Ford part number E5AE-8509-DA - $5
Stock HVAC control unit. Not perfect looking, but it works. Needs lightbulbs - $20
Stock Speed density ECM (Ford part number E6SF-12A650-L1C). This is the one that does NOT control the cruise control - $40
Pictures of everything are here
All parts were removed from a 1987 LSC and have been sitting and collecting dust for a few years. I'm sick of looking at them. Prices do NOT include shipping (although I can't see this stuff costing much to ship).
Thanks!
Staff online
