major problem I think
bigrdubs
cleveland
Ok so I pull in the driveway with my wife and we end up sitting in the car talking for about 15 minutes with the car off but with the key turned to the on position so that we can use the heated seats. We had the radio on and the lights were also on. Well, after about 15-20 minutes my display flashed to check the advancetrac system. Then my radio started acting weird like it was searching for a cd and then it just totally turned off and wont turn back on. My headlights work but my fogs dont. The car willl not start up or crank at all for that matter. Can anyone please help me. Thanks in advance guys.
That's alot of accesories to run when the engine isn't. :eek:
Did you also have your foot resting on the brake pedal?
"note to self" dont let me wife talk while in the car...
You should never just sit with the key in the on position without the motor running. It should be in the acc. position, off or on with the motor running.
'Talking' in the Car
You should go in the house to 'talk'. I haven't 'talked' in a car for more than 30 years! ;)
KS
