Magna-packs (14416's) are on! =) me likey!
Former Member
there you go.
I LOOOVE it. its quieter at idle, but meaner sounding when revving it. I also think the magnaflows added some power. The old spiral flows were very rusty on the insid probably restricted some flow.
heres the old moroso spiral flows.
Oh btw they are stainless steel, can get em from summitracing.com for 67.99$ a peice
Dude, you need a new job. I can't believe they actually make you WORK...
how much work can they actually be MAKING him do if he is always on here? jk, i only get on here at work and the fun blocker got me too.
Work blocking Photobucket makes me sad. :(
Dude I know. But try this, it worked for me. Just recently found a way around the work blocked sites.
In IE pick the "tools" pull down
Select "internet options"
Under the "connections" tab
pick "LAN settings"
On the bottom there is a checkbox for "proxy server"
Make sure this is NOT checked.
Then try those blocked sites. Worked fine for me.
Nice Magna-packs by the way!!
It''s a firewall issue and how they filter stuff here. Not using a proxy server and I won't get to any site. :( Thanks though - I'll just wait until I get home.
its worth the wait, i get a smile on my face when i start my car now. since the rattling is gone cold starts dont scare me anymore either.
bought a spectre air filter and spectre MAF adaptor at auto zone today. 24.99 for the filter and 11.99 for the MAF adaptor. holes needed to be drilled to fit. Its on now, just waiting for the parts from intakehoses.com to show up. got the pipe barbs and PVC all ready to go
I have the same current spectre filter setup. Are you planning ou running the filter down out of the engine bay?
no, it'll stay in the engine bay. when my parts show up im building a 3" intake from MAF to T/B. i wish i couldve done the ram air, but im just too worried about it not being enough room to actually get a gain.
So do you still have the factory resonators? Or just the Magnaflows? Because I was going to use the 10426 which is the Stainless version of yours, only in a 18", a Magnaflow X pipe 10791, and then use the 11226 Mufflers (4x9x14). Those are the same resonators, x pipe, and mufflers the Magnflow kits uses only in a 2.5" version, and then use Roush dual outlet tips and have the rest of the pipes made locally.
No resonators, the 14416's are in place of the stock resonators, X pipe is in front of those, and then straight out to the dual 3" Flared SS tips
