If you're talking about the adapter plate so you can attach a cone filter, I got one at OReilly's for like 6 bucks. Works great. In fact, I got a Spectre cone filter too. I think everything with the silicone coupler was about 40 bucks. Probably less than that though.
There was only one size adapter when I bought mine. I forget the size of it. But I did have to go to a hardware store for the bolts/nuts/washers. And I had to redrill the holes on the adapter plate so they would line up properly. Then I used some foam tape in between so there was a good seal between the MAF and the adapter.
If you want a MAFS adapter that looks very presentable and functional but with a little more cost then go to LSKoncepts. I believe he has a few of them available.
If you are into just pure functionality and bottom price then go to your local auto parts store and pickup a machined aluminum universal MAF adapter there. You will have to probably do a little redrilling of the holes to fit your MAF bolt pattern though.
