LS shuting down"""
johnls
san gabriel
Hey whats up a have a 2000 ls the car keeps turning off when i get to a stop light it turns right back up. I hade the puel pump replace the trasmision check and the pcm replace i dont know what is wrong with it ? need help thanks ...:confused:
Will it start right back up? If so its most likely your IAC (idle air control valve) Super problem part on fords.
i've had the same problem on my galant. I'm not sure what the part is called, but it has a flap type of device on it. i think it is the icv valve. anyway, over the years and miles it had a ton of build up which was causing the value to stick and stay shut. it would come to a stop at a light or toll plaza and just die on me. start right up again. it would also do this drop in rpms from about 8oo to 400 when i was at a red light. engine would shake as if about to cut off. \
shop took the part out to clean it and never had the problem again.
This thread would have helped me about 6 years ago when I junked a car with 68,000 miles because nobody could figure out why it was doing this.
i hope is that cause this mornig the car was acting funny i put in d' and it would move put it back to park and back to d and it move the dealer check it a couple of days ago and said that the trasmision was fine
You saying when your idle was higher then normal and you put it in D the car would lunge abit? Check to see what your RPM's are when your shift from P to D. Idle rpm should be 800 ish. If its higher then 1000 it might creap on you. Keep your foot firmly on the brake pedal.
I was replying to your above post. Please double check what you wrote because I answered what you where saying as a problem. I was trying to figure out what you where trying to say.
