A recent forum update broke the links on the thread that @RollinLS put together a while back. So I decided to take some time and fix it all up, so that it's easier for newb's to find what they need. Might fix some other threads if I find myself with some time to kill.
www.lincolnvscadillac.com
Jaguar Wheels Fitment Database
I feel I’ve owned enough of these, and there is enough interest among the community that I wanted to get this “database” sort of speak, going that explains which wheels fit, with what equipment, and of course their specs. Rolling has a similar thread going but I wanted this one to be specific...
Wheels 101
Wheel Tech Guide Everything You Need to Know Before You Buy Source: Modified Photographers often say that wheels are a car's jewelry. Perhaps more than anything else, they immediately show the tastes and character of the owner who put them on. It's obvious whether the driver is a poser who...
Lowered LSes Heights & Equipement Used
We always have members wanting to know ride height with various equipement used. We have enough lowered members to start a baseline of information. Need to know what equipement was used: spirngs brand, cut coils, tire size, v6 or v8, etc.... Please measure from ground to bottom of fender all...
For those looking to do bumper cutouts...
A few people have asked how to do the exhaust tip cutouts by pm'ing me, so I figured I'd share with everyone what came from the last round. I took a picture of the tips how they come through right now. I added some arrows and descriptions on how to do it like I did. I also included a picture...
Double DIN Installation Proceedure w/front factory tweeters
This is a Double DIN installation for 2000-2002 Lincoln LS. This system uses the factory tweeters in the console and the factory subwoofer system. Note: For best results the rear Subwoofer upgrade has to be performed 2000-2001 (See "Subwoofer Upgrade 2000-2001" Post) and the correct factory...
How to Install Mach 1 Chin Spoiler (pics)
There are a few different ways to mount a Mach 1 Chin Spoiler on the LS. This is a guide to get the most professional and stock looking finish. Tools/materials list: Self Tapping Screws ¾” Drill with adapter for socket or screw driver to fit the screws Washers that fit on the screws, but...
Angel Eyes Installed...Lots of Pics
Sorry for all the pics....i know you guys like a lot of pics though. All of them were taken with my iphone so dont mind the quality. I did all of the work myself, pretty easy if you are somewhat mechanically inclined. I decided to paint the bezel while i had it...
LED Angel eyes Install- A lot of PICS
So I finished the angel eyes and here are some pics of them. They came out great, overall not as hard as I thought. The hardest part was cutting them open. The dremel part was easy, I just cut in deep enough to cut the black lip off, but then I had to use 2 flat heads to lift the headlight off...
Lincoln LS 12.6" Brake Upgrade Confirmed
It all works! In a nut shell. Here is what I have learned: 1) Thought the calipers were iron, nice surprise there 2) I hate those stupid rotor retainer clips!!! 3) They are not squeal tabs, they were anti-rattle clips, oops :) But since no one cares about that, here's the deal on it all...
2007 Jaguar STR Brakes Confirmed
Fronts are a direct bolt on. Jag bolts are a little shorter. Jag stainless brake lines are the same length as LS factory lines. LS rotor is 11.81" Jag STR rotor is 14" 18" wheels are a close fit. If you can replace your brakes you can do this swap.
Powerstop D/S Rotors & pads Installed on LS
I finally had time to install the Powerstop drilled and slotted rotors with ceramic pads. WOW!!!! I still have to break them in. Already notice a HUGE difference in braking. They are just an OEM replacement. Same size as the factory brakes. Very happy with them.
