Belated Happy Thanksgiving.
Experienced lag (twice) with my 2000 LSV8 during shifts at higher speeds. Display showed "Check Transmission". Did search in forum regarding tranny probs. Taking it to the dealer tomorrow and will post diagnosis asap.
FYI,
Here's a link to "all" TSBs for 2000 LS V8
http://www.ford-trucks.com/tsb/tsb.php/m-LINCOLN/y-2000/d-LS
also.......
TRANSMISSION SERVICE FOR THE NEW FORD 5R55N
In the ever-changing world of automotive technology, professional automotive service providers must be prepared for whatever curve ball is thrown their way. This months tech tip deals with just this sort of thing as it relates to transmission services for the new Ford 5R55N transmissions, found in the 2000 and newer Lincoln LS and some Jaguars. Some technicians may be thinking, now how many Lincoln LS and Jaguars does the common fast lube facility service each month? The other thought process is that this new type of transmission application must start somewhere. This type of transmission technology as it applies to virtually sealed and or self contained units will eventually find its way to many other makes and models of vehicles. Fast Lube operators and technicians will start to see them more frequently, so familiarizing ourselves now will only put us ahead of the game. Prior Preparation Prevents Poor Performance!
POTENTIAL PROBLEM: The service technician releases the hood of a vehicle containing the 5R55N transmission, with the intent of performing a transmission flush or fluid service, and he or she notices that something doesn’t look right; there is no dipstick to check the transmission fluid level. How do I service this vehicle?
SOLUTION: Have the pit technician look closely at the 5R55N transmission pan and identify the drain plug, to check the correct fluid level they will notice the check plug which is located in the center of the bottom drain plug. Holding the drain plug with the proper size wrench so as not to loosen the drain plug, proceed to remove the check plug with the proper size Allen wrench. If the transmission is operating at the proper fluid capacity the transmission fluid should just trickle over the stem and out through the center of the drain plug. In the event that no fluid is released, this is a good indication of low or improper fluid levels.
Installation of new fluid: To install new fluid in the Ford 5R55N transmission, locate the (Fill Plug) in the extension housing of the transmission, the plug is identified by instructions for transmission fluid application.
FYI,
also.......
