I have not done this job on the LS... but I've certainly done this type of things on other cars, and from looking at the factory manual... even if you are just slightly smarter than "retarded", it shouldn't be a problem.
Some of the nuts and bolts need to be replaced too. They are single use once they are torqued. Check a manual to see which ones, but I am sure that at least the lower ball joint nut needs replacing.
