low idol
joeydm090682
woodbridge
i was driving my 94 mark with 70k back home from south jersey when i was near my house i decided to fill her with gas befor i put her in the garage, after getting gas and starting the car it idols now at 400 rpms. did i get bad gas? did something wear out? what should i look for?
Could be the O2's... mine did that every once in a while until I replaced them. For now, drive it a little more and see if there are any more symptoms before we can decide what the problem is.
Does it also over-idle? Too high sometimes? If so, it's your throttle control sensor. Mine did that too.
Is my throttle position sensor hard to change, what is the proper way to do this, do I have to take my throttle body out in order to change my throttle position sensor.
I took mine to a mechanic.
