I replaced the sway bar end links about a month ago. Then 3 weeks ago I was hearing a large clunk in the front end. Taking the front right tire off I found the sway bar bracket .. the brackets attatching the sway bar to the frame ( replaced just over a year ago ) had been torn in half. So I replaced it.
Now the car is making a very loud whine when at high speeds. The front and rear hubs have been replaced within the last year but I still suspect it's from one of the hubs. (I don't remember if the front were OEM (tinkin) but I know the rears were.) After taking a friend around in the car we thought the front right tire was most suspect so we put the car up on jack stands and tried to move the tire. It did move just a very small bit from left to right. I took the brakes off... make sure everything is tight and still there is that bit of movement.
Also, In in the last month I have developed a leak somewhere in my power steering system. It is also about a year old. It leaks about 1/5 of a quart every week and the sound is there even when it's full. (but also the sound of not enough fluid in a power steering system is there when the fluid tank is full.) I don't hear any engine whine when the car is idling from under the hood either.
Any ideas about what's going on here?
