freeradical
I do not know a lot about troubleshooting and I am trying to determine what is throwing codes and causing my ls to run like garbage, all of your help is appreciated.
I know the LS has problems with Ignition coils, This is something I don't want to replace unless absolutely necessary due to removing the intake manifold. and I don't have a lot of money to throw at this problem.
I own a 2003 Lincoln Ls 3.0 V6, It has 32,000miles, The only modification on the vehicle is a ram air intake.
The vehicle was running fine after the intake install,
It is drivable, however the vehicle is beginning to periodically lose power and make a popping sound as if it were missing and then within 5 seconds resumes acceleration, though it runs as if only accessing 75% of its potential.
About a week after the intake was put on It threw a single code, I believe it was P0172 dealing with the fuel/air ratio being too lean on bank one, 2 days later I received a second code P0174 pertaining to a lean mixture on bank two.
I was afraid that the new intake screwed with my MAF (Because i'm getting codes on both banks) so I have cleaned the MAF twice, disconnected the battery and reseted the computer both times, and I notice an immediate change in response and performance, but the problem comes back.
About a week later It threw 3 more codes, P2196 and P2198 both dealing with 02 sensors stuck rich, bank 1 and 2.
Also P2106 - TAC system forced limited power. (No idea?)
My next step from what I've been researching is to check my fuel pressure at the rail, and make sure my fuel pump relay and fuses are working correctly?
Would I use an altimeter or multimeter or something like this?
I'm also planning on replacing the fuel filter for the hell of it because I believe this could also cause a similar problem?
So would I be correct in assuming that I might need a new maf, spark plugs, ignition coils, o2 sensors, timing checked, fuel filter, or fuel pump?
How can I eliminate all the guesswork and get this problem resolved cheaply? >.<
Is there a recall on the ignition coils or something? should i take it in to Lincoln and let them poke around?
