Longer Wheel Studs
  • Thread starter Thread starter GrayGhost1
  • Start date Start date
G
GrayGhost1
Guest
I'm trying to find longer wheel studs for the LS. I know these standard specs on the wheel studs:
- 12 mm x 1.5 mm
- thread length = 2.22" long
- knurl length = .52" long
That equates to about 56 mm thread length. I need to have a wheel stud about 63 - 65 mm long. If anyone knows of a place that sells or makes these let me know.
I contacted them and they may be able to make them. Anyone else?
Try calling Summit or JEGS they have a ton of options for studs. Don't go by what is in the catalog either, that is just a sample of the parts they have available. If they don't have any to fit they will most likely be able to put you in contact with someone that does! Good luck
