marksarcade
Happened twice today, turned off the ignition and tried to unlock the doors, and the passenger side unlocked but the drivers side would not unlock. The actuator was acting like it was trying to unlock door, but it wouldn't unlock. Could not pull up door lock manually or unlock with transmitter, just seemed like the knob was trying to come up and unlock but might have been stuck on something or binding, not sure. I was only finally able to open the door by pulling on the inside door handle and also pulling up on the door knob at the same time and after doing that for awhile it finally unlocked. It only happens when I'm in the vehicle and turning it off, and trying to get out of car. Also are you suppose to be able to remove the ignition key in any position , even in the run position ? or is my lock cylinder just worn out. Thanks all, any help would be appreciated.
