Little help
GSXRDUDE
So Cal
Went sideways into a curb last week, Sheered TIE rod mount off of control arm, bent the tie rods, control arm's, stabilizer bar, hub bolts, steering geer on the front driver's side the rear has broken tie rod conecter and rod and a few sheered off lug nuts. Good news is not one scratch on the car or creases, cracks or other damage in and arround the suspention. Yesterday I picked up all the parts on the list in great shape for 300 bucks. What order should I install them and any info I should know before I start. Thanks.
Well, there's a lot to know, but one thing that I would like to point out is that you need to replace all of the nuts that you have to remove. They are all one-time use and if you reuse them, they will come loose after a little time.
Also, any aluminum parts that were at all bent must be replaced.
