Little help with the neon.
12welvemonkeys
Brighton
Hello All,
I recently purchased a inverter from Glitch and installed her a few weeks back. Everything is working fine........ or so I thought.
I was following my wife home the other day (in the day) an noticed that the neon was barley noticeable when braking. So, I removed it again and made some adjustments at night.
The issue is that the light level has to be set really high to look close to the tail lights when in parking light mode, but at that level the brake light won't show when applied.
When I adjust the level back down so that there is a difference between the brake and the parking light level.... the parking level looks low and the brake level is also weak??????
Not sure what the deal is? I believe that I installed it properly and I have seen others on the forum that have the Glitch inverter installed and it looks great!!!
So any info or suggestions would be greatly appreciated.
Thank you for you time.
Joe V
