Lincoln LS new owner hep!
Wingsfan19
Mt. Pleasant
Hi all,
New to the forums here. I just purchased a 2000 Lincoln LS with 106k miles. I did a carfax and it looks like it has been very well maintained. It is in good shape for the most part and I knew going in that I was going to have to put some money into it being 12 years old. It drives great, but so far I have experienced some issues which seem to come up frequently with LS owners.
I have the issue of lack of heat when the car is in idle or low rpm. At first I thought it was just a dccv issue, but today it overheated while idle and I wonder if it's something more. Without a dealer nearby, I wonder if this is something that a local mechanic will be able to fix. There are a few good ones in the area, I just want to know if this is a fixable problem or if I have to get it to a dealer. I only get significant heat when the car is on main roads or on the freeway, so I have a feeling that the idle overheating and idle heat output are related. Any ideas?
Thanks,
Brian
It may be possible that there was work done on the car and it wasn't bled properly, I would suggest you bleed the system and see if it does you any good.
