Hi. the title says it. Its not hot airjust warm. But after drivin 20 miles the air wuth finally be col. Whats going on?
I'll go against the flow here. It sounds more like your R-134a (refrigerant) is low than your DCCV failing.
The key points are: (1) gets better while driving, and (2) passenger side warm but not hot.
I would think that an R134a problem would hit the entire system, not just one side. Can you explain how this would be a refrigerant issue?![]()
Good info. So in your opinion if the refrigerant is not the culprit, the dccv is next in line as the root cause?
Joe, one more question now that I am thinking. Would the possibility of low refrigerant perhaps indicate a small leak? Maybe an o ring? I ask because my system worked fine for the 6 years I have owned the car(until the issue we discussed via pm) and never needed any refrigerant added. It simply worked year after year.
Due to the design of the evaporator and the thermal expansion valve, when the refrigerant level gets low, the cooling stops at the far side (passenger side) of the evaporator. As the level goes down, eventually, there will be no cooling at the driver's side either.
i did find out what was wrong today with my car. it turned out unfortunately to be a combination of several things. first the hydraulic fan is going out so that explains why it doesnt start to cool until driving fast, then the dccv fixed the problem with warm air on the passenger andddd it was a tad low on refrigerant.
