V
vktrenz
Guest
I currently own a 2000 Lincoln LS. My battery died and wanted to start it back up again. I increased the amps and boosted the car up. Before the jump and before the battery died. I had no "Check Charge system light", but right after I jump started it. The light came on, and I checked the voltage. It showed me 13.3V. I changed the battery and the light was still there and still 13.3v. I changed out the alternator 4 times and same problem and same 13.3v on the battery and the generator when the car is running. The voltage regulator is on the alternator and it still shows 13.3v. I added another ground and cleaned positive and negative leads. traced wires and found nothing. So I decided to unplug the alternator plug on the alternator it self. after doing so I check the voltage and it showed me 13.8-13.9v! I was surprised, but once you plug the alternator plug back on. It reads 13.3v again. I bought a new pcm and take the car to the dealership to be programed, and the programing fails. I find out I gave them the wrong pcm. I was not compatible with the serial numbers. I brought the car running, and when they tried to hook up my old pcm, the car doesn't start. Dealership searched and searched and could not find what the problem is. They checked everything from fuses to solenoid to tracing wires, and came up nothing and said they cant find or don't know what to do next. Now my only option left is to get a new pcm with the right serial number and try again with the programming. My question is this, if I put to much amps from a jumper box could I burn the pcm? Or any other ideas?? Thanks
