Lincoln LS bolt pattern question
Gottie
Cola
I was looking for some rims but i am confused about the bolt patterns. Lincoln LS has a 5 x 108mm pattern but I can't find much for them. Will a 5 x 114.3 possibly somehow fit.
Only if you can get them redrilled.
If they have an offset of 60 or greater, you can get adapters.
Rather than redrill the wheel or use adapters find out about getting the hubs redrilled along with the rotors unless you can find the right rotors in that bolt pattern.
When you redrill a wheel they weld in the hole. If you have a center cap that covers the lug you could get them drilled around the old bolt pattern but doing the hubs from what I gather with people in our same position is totally safe, much safer than redrilling the wheels with that fact.
