keez
ok so i'm on the way back from wallyworld and make a left turn...the LED on the driver's side just decides out of the blue to work...so the other probably needs a bulb or something right? or could it be wiring gone bad? both are on the same fuse I would guess .the puddle lamps work so im thinking its got to be the individual part but if that is the case why doesn't the driver side work all the time....obviously i'm confused here
