LED Blinkers/Lamp Out Module
jrizzle
Delray Beach
I recently replaced the blinker bulbs with LED bulbs. This seems to be causing the Check Exterior Lamps message to come up. Ive snipped the wire for my HID lights, but which one controls the blinkers front and rear? Thanks!
The module doen't monitor the front signals, just the Low-beam Headlamps, rear park lamp and Rear Stop/Turn Lamps...
You need to disconnect the BR/LB wire for the HID's (front low-beams), so I'd imagine you'd need to disconnect the LB/O, R/W, and W/LG wires from the module too as they are the left rear turn, right rear turn, and rear park lamp sense wires respectively...
You would lose all Lamp Out warnings by doing this though...
Not that that really bothers me but I will try resistors first. What about the high beams, I am doing the HID upgrade to the Hi Beams today as well, does the module monitor them?
If your trying resistors, make sure to keep them away from anything as they can get hot...
