Leaking Roof, Help!!
DUVALINCOLN
Tally
I was sitting in my 04 Lincoln LS and noticed it dripping water in the upper corner of the driver side door frame. I ran my hand along the top of door frame and roof but, the corner was the only part currently wet. I went to the dealership and they said it might be the drain tube from the moonroof is clogged or not attached but they are unable to get to it today. I would definitely like to solve problem myself to save in cost if that is possible. How can I correct the leaking myself? And is it worth the trouble to do myself? Thank you.
