leaking power steering pressure hose
gtnrb71
california
I am new here and have an 2002 ls v8. I noticed a leak from the power steering pump. I changed the pump and the pressure line but I can't get the metal hard line that goes to the pump to seal. It keeps leaking in between the hard line and the nut that screws to the pump. I have the o ring and the white plastic washer on there is there something I am missing? Thanks in advance
Thanks for the pic what looks different is that The part hm1 looks like the plastic crush washer that I got with the hose, but the other two seals don't look right. The piece that won't seal is a metal hard line that goes through a nut that screws to the pump. The tube is then flared like a compression fitting. So the other two seals wouldn't do anything since they would be on the wrong side of the nut that screws into the pump housing which is where the leak is between the tubing and the nut crimped to it
