Leaking Gas
GMAN
Spring, Texas, United States
This morning I fueled my vehicle. After I was finished, I noticed gas was leaking out somewhere underneath. I was only three miles from work, so I proceeded on. When I arrived to work, I checked underneath again, it seemed to have seald itself. What is this a sign of? Fuel tank or fuel pump?
prolly a fuel pressure line. could be a pinhole and when you shut the car off, the pump was no longer creating pressure in the line, so no fuel was getting blown out...
Frat-man-du said:
Could be you just over filled some and it spilled out the overflow tube.
i missed the part where u said you fueled up.. i agree. could have overfilled.
I think that is unlikely. I am going to check it on the next fill up. I usually fuel until the pump clicks.
I've also been getting the check engine light lately, and I had it checked. It came back with bank 1 lean, and check VCRM. Does the VCRM control the fuel pressure or anything dealing with the fuel?
The VCRM controls the fan as well as low speed fuel pump operations.
