just sharing a local nightclub flyer with a ls in it
Hernandez
Mexico
looks like our car is good enough for a fashion night out
Looks like an LS. I would probably call BS though. A car like the LS would not make a good stretched limo. Those are almost exclusively chassis-on-frame cars, like the towncar or escalade. Plus they usually share drivetrain components with trucks which means you can push the lead sled through the streets. Doesn't mean that it's not possible.
I've never seen an LS limo, I think it would look great. But I'm bias of course ;)
It would be a pretty small, in ride height and internal dimensions, for limo service, specially as a stretched limo. Photochop can do anything though.
It's an LS but not a limo.
OP never said it was a limo but photoshopped nontheless.
Good call Kumba.
If you were to take a look at the photo at a 5 degree angle instead of the normal
90 degree, you would see that the roofline does not line-up properly with the other
half and the lower window lines are at two different angles.
I need to stop watching forensic tv shows.:shifty:
Good call Kumba.
Still looks like a Limo in the picture, irregardless of what the raw picture started out as.
can photocop fix my sway bar woes? :p
Cool flyer ! If i were you I'd keep that. (I swear I'm NOT a packrat !) But it's an interesting piece of LS memorabilia. :)
