Jim Henderson
After letting the car sit for a few hours I was able to get a better look at the leak from the thermostat housing.
Short answer is it is NOT the Tstat housing, it may be either a bad "Radiator Cap" or bad O ring on the cap. Or some problem with the hoses near by. The Housing is Most likely OK. I haven't 100% solved the problem but suspect the items mentioned above, or it is a waterpump issue, arrr. Need to confirm.
Long answer and a few corrections...
The "Radiator Cap" Does NOT have a spring loaded seal. Or else mine is busted and doesn't move. I am used to radiator caps with a spring seal, so I must have imagined that is what I was holding in my hand. There appears to be some sort of plunger inside the cap or else it is just a cavity in there for some purpose, it doesn't move. The O ring seems to be somewhat flattened I would guess from old age and maybe is not sealing fully. The inside of the tstat neck feels like somewhat soft rubber, the O ring seals against the inside of the neck against the rubber.
The Thermostat housing has a small 1/2" hot dog shaped hole on the inside of the neck which is supposed to be there. It is most likely a overflow vent for over pressure problems.
So I am guessing now that the O ring or cap are not properly sealing and is releasing water thru the vent hole and spilling onto the pulley and splashing around which is what left me clues that this general area is where the problem lies. So it is either the cap, nearby hoses or a leaky pump. I hope it is just the cap O ring since I have those at home and basically the fix is free.
Otherwise, I need to find the cap, which so far isn't on Rock Auto but the Cap adapter(Tstat Housing neck) is, strange they would have that, but I don't think I need it. Or it is the pump which goes for $40 to $90 depending on rebuilt, probably new china made or OEM.
I will probably replace the O ring this week and see if that works. Then maybe a new cap if it doesn't. Hope it isn't the pump, but so far no hard evidence of that being the problem. I need to either see it leak or crawl under the car to check the weep hole.
SO, I am either an idiot on a wild goose chase, or maybe I get lucky and fix this for cheap. Either way I'll post what I find.
Jim Henderson
Jim Henderson
