IRS brace
fossten
Louisville
I'm ordering one for my 93. Is there anything in that area that I should replace before putting it on? If I decide to do my exhaust later, will that be in the way?
Also, is this a straight bolt/weld using existing holes?
The rear brace is a direct bolt up..the front needs 2 tabs welded to the sub frame..
The rear will need to be removed in order to drop the exhaust, but it's only 4 bolts, and easy to do
