Intermittent ABS Stutter/Pulsing
SHO992
Toronto
I hope someone can answer this question since what I'm being told it is going to be expensive to fix.
I have searched every possible wording but can't find the answer to my problem.
I just got my 2001 LS V6, manual 5 SPD back from my mechanic. I had the ABS, Traction Control and Brake lights on because of a bad front passenger wheel bearing which in turn destroyed the ABS sensor (so I'm told). Now all the lights are off but under "light" braking on dry roads the ABS is kicking in and pulsing the brake peddle. It is itermittent but seems to only happen under light braking. They are now telling me that Ford told them LS's have wiring problems in the harness that causes this.
Any ideas what it could be?
The first thing to check would be the gap between the wheel sensor and the tooth ring on the repaired wheel.
