So my Drivers Door seems to be fussy at opening but has never failed me yet. Is replacing the Door Handle the solution most of the time? It opens fine from the inside so perhaps I need an Outside Door Handle?
Got two out of three LS'es that have slightly loose outside door handles but still in working order. It's a gentle operation opening and closing the doors. Also on the to-do-lists.
when it doesn't open, are you 100% sure that it is actually unlocking? the actuator may be struggling and making the noise but not able to fully unlock the door.
Also on the to-do-list for me. I have bought the front handles already though. So they are collecting dust until i get the wild hair to actually swap them out.
I'll have to check function on an unlocked door and post a result.
I gave the lock a spritz with the lithium grease and then ran a few errands today, making note to not lock the door. Don't know if I was imagining it or not but it may have been easier to open. I'm taking the Door Panel off later in the week to replace the Speaker so I'll get a better look, and give it another spritz of lithium from the inside.
