injector wire plug
Cams-76
Oregon
i was trying to unplug the injector plugs off the injectors and the little clips broke off on 2. is this common? can i just plug em in or will they vibrate out?
Yes.
Yes.
You can either purchase new connectors (p/n 1F1Z-14489-AA) and move the pins into the new connector or you can zip-tie the connector to the coil. I did this with a couple but was a little leery on how effective it would be. When I replaced the connectors I noticed the zip-ties were starting to get brittle from the heat.
